1998 Mitsubishi Montero car audio and lights
1998 MITSUBISHI MONTERO
155,000 MILES • 6 CYL • 2WD • AUTOMATIC
GIO6191993
  • 11 POSTS
my cars antenna goes up and down when i turn on and off the radio but doesn't go down when i turn off the car and the light only sometimes go on when i open the door
Jan 22, 2010 at 5:31 PM
KHLOW2008
  • 41,814 POSTS
Hi gio6191993,
Thank you for the donation.
You have 2 problems and they are :
1. Antenna not going down when ignition is turned OFF. A constant power source is missing and if any wiring had been done prior to this, recheck the wiring.
2. Dome lights intermittently not working. Check the door switch, its contact could be bad and sometimes not connecting.
Jan 25, 2010 at 11:14 AM
GIO6191993
  • 11 POSTS
thanks i fixed it it was the constant power source was disconnected once i did that everything went back to normal
Jan 25, 2010 at 1:18 PM
KHLOW2008
  • 41,814 POSTS
You are welcomed and glad that you have resolved the problem.
Have a nice day.
Jan 25, 2010 at 1:28 PM
