to start with, i never aligned the marks before i went ahead to remove the belt.
but i tougth that if i didn't move anything i was goint to be able to install the new belt back and no problems.
well i did install the new belt and try to rotate the crank to see that the marks lign up and they don't,
also when turning the crank clockwise i can hear something kind of touching on the right side of the bank.
my question to you is,
should i remove the belt and rotate the marks to lign up and if i need to do this how do i know when the cylinder 1 is up or tdc as you may call it?
Apr 29, 2008 at 6:57 PM
