Engine Mechanical problem
1994 Mitsubishi Montero 6 cyl Four Wheel Drive Automatic alot miles
i have a oil leak while the vehicle is running its right above the oilpan where the crankshaft and belt meet the oil pan when the vehicleis running it drips/leaks right under the pully and belt by the oil pan. is it the oil pan gasket? and if so what is the easiest way to get at that thing?
Apr 26, 2009 at 9:13 PM
