My car has lack of power off the line but at higher speeds when I kick it down into passing gear it seems to have plenty of power. I also can hear some back fireing once in a while. A local machanic said it was two fuel injectors. I have listened with stethiscope and can hear injectors working and speeding up when engine is reved. This car has no egr system? I thought that was it but no. One injector under the plenum I could not hear, I could not get stethiscope on it? This car has no computer terminal to check codes from?
What would you suggest?
ps. I have changed the fuel filter and the plugs and wires. This car also dose not have a pcv valve, it only has a straight open tube into the valve cover? i HAVE DONE ALL THESE THINGS THAT HAVE BEEN SUGGESSTED IT EVEN JUST PAST I/M WITH FLIING COLORS!
COULD IT POSSIBLY BE THE COIL?
Jan 7, 2008 at 1:36 PM
