My first time here...2002 Mitsubishi Mirage 1.8L with slight hesitation in 1st and 2nd gear. Poor acceleration all through out the powerband. Will not go faster than 70 MPH on flat surface (3000 RPM, 5th gear). After 3000 RPM (4th gear), engine boggs down at WOT and seems to actually slow. CEL came on prior to this and I checked it. EGR valve problem. Found major carbon buildup inside. Totally cleaned and removed the deposits. CEL is off now but symptoms persist. Changed plugs and wires. Symptoms still there. Did a compression check, 180, 175, 180, 175....all good and strong. Symptoms still there. Unplugged front O2 sensor, no change. What else could cause this?
Sep 8, 2010 at 12:26 PM
