2001 Mitsubishi Mirage A/C will not blow
2001 MITSUBISHI MIRAGE
170,000 MILES • 4 CYL • FWD • MANUAL
MFENIX13
  • 4 POSTS
Recently in our neighborhood there were heavy rains and the storm drain clogged. The water rose pretty high and my car was flooded on the inside. After that day the A/C will not blow air out of the vents. I checked all the fuses and they are fine, I have replaced the Blower Motor and the Blower motor resistor pack, but it still will not blow. I just want to know what other things would be causing this.
Jul 29, 2009 at 8:29 PM
Check and test the blower motor relay,blower switch and the ground circuit at G302 under front end of center console
Jul 29, 2009 at 8:46 PM
MFENIX13
  • 4 POSTS
First off, thanks for your help, I really appreciate it. A couple of questions:
1. When you say the blower switch are you referring to the A/C control knob that turns the A/C on?
2. What's the ground circuit look like? I'm assuming it either looks like a wiring harness or a cable attatched to the chasis directly.
I have the Chilton's repair manual and I couldn't find anything on these two subjects, and I also looked online but couldn't find anything either. Thanks in advance.
Jul 30, 2009 at 4:22 PM
Is this a DE, ES or LS Mirage?
Jul 30, 2009 at 5:18 PM
MFENIX13
  • 4 POSTS
It's a DED with a 1.5L engine.
Jul 31, 2009 at 9:33 PM
