2001 Mitsubishi Mirage #2 cylinder misfire code
2001 MITSUBISHI MIRAGE
150,000 MILES • 4 CYL • FWD • AUTOMATIC
SWATMONKEY
Hey guys,
I have a 2001 Mitsu Mirage, bout 150,000 mile. bout a week ago the engine started to stutter I took it to a auto parts store to put the diagnostic meter on it. It read that the #2 cylinder was misfiring. I started small and got bigger in my troubleshooting.
1. Changed plugs and wires
2. Changed coil packs
3. replaced fuel injectors
Now, I'm not sure what to do, any advice would be great thanks.
Jonathan
Mar 24, 2009 at 3:07 PM
Next check compression
Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Mar 24, 2009 at 3:32 PM
