Clutch Installation
2000 MITSUBISHI MIRAGE
181,000 MILES • 4 CYL • FWD • MANUAL
JEANIE_B_Y
We are trying to change the clutch and are having difficulties. I have the Chilton Mitsubishi Repair Manual but I'm not able to remove the existing clutch. I can't figure out what bolts to take out to remove the clutch. I have the driver side axle out. Do both axles need to come out?
Could you please respond as soon as possible? Also, do you know of a video I can see?
Thank you very much,
Jeanie
May 30, 2010 at 9:41 PM
BLUELIGHTNIN6
  • 16,542 POSTS
I would start by disconnecting the battery and draining the coolant here is a video of the clutch replacement on a similar car the procure is the same on your car
https://youtu.be/6N6b5F2ChyE
This guide can help as well
https://www.2carpros.com/articles/how-to-replace-a-clutch
May 30, 2010 at 10:08 PM
