2000 Mitsubishi Mirage Brake lights are not working
2000 MITSUBISHI MIRAGE
144,000 MILES • 4 CYL • 2WD • AUTOMATIC
KATALYST
I had a car sterio deck installed, and discovered recently that none of my brake lights are working. I'm not 100% certain it's related, but I would assume so. How should I go about diagnoseing the problem? I replaced the fuse and it did not change anything. Should I next replace the brake switch, maybe the installation guys broke it while playing around the dash? If so how do I go about fixing that in my make/model?my last concern, should I be concerned about an elleterical short that occured? Is that an expensive problem to fix? Thank you in advance for your time and help. Any ideas or a are helpful.
Thank You,
Kathryn
Sep 3, 2009 at 10:35 PM
Maybe the stereo guy short out the brake circuit-check the stop fuse and the brake switch
Sep 4, 2009 at 1:06 AM
