Car started fine, idled fine, hesitated for a few seconds when put in gear then would drive OK for 10 minutes and stall. would restart after cooling for 5 minutes. Replaced: plugs, wires, distributor cap/rotor, distributor/coil (used), fuel pump, and fuel injectors. no change at all. sprayed butterfly at throttle body with carb. cleaner, now it idles worse and I can see (and smell) unburned fuel running into the exhaust manifold. I checked the plugs and wires, all of the wires tested OK, the plugs were installed correctly and all four continued to foul. any ideas?
Feb 28, 2010 at 11:12 AM
