i need to know the timing marks on the pulleys where the timing belt goes they got moved and now car wont start
Feb 23, 2010 at 9:37 AM
BLUELIGHTNIN6
CERTIFIED EXPERT
Feb 23, 2010 at 3:07 PM
EDIGAR57
MEMBER
I own a mitsubishi mirage de 97 recently it started leaking out all the anti coolant I literally have to keep toping it up as I drive. but I noticed it leaks out just below the timing belt area. What can I do to stop it?
Jul 18, 2019 at 12:53 PM
(Merged)
PROTECH1980
MEMBER
I not positive, but the water pump is probaly timing belt driven and has gone bad, only fix is to replace the water pump if that is what is leaking, to find out for sure you may have to remove the covers to pinpoint leak.
(Merged)
EDIGAR57
MEMBER
Thanks @ protech1980, Can I fix it my self, I mean the whole water pump replacement process? I f yes please send me some video links and steps on how to do it.
Please I am at your mercy.
Finally, after opening the covers how can I tell that the water pump is broken? how does a broken one look like and how does it behave?
(Merged)
DANIELJBENDER
MEMBER
1 POST
On the lower gear I aligned the circle on the gear with one at approximately 12 o'clock or slightly later, on the top it currently is around 3 o'clock and the rooter points to 11 o'clock not 4 o'clock where piston 1 is. The books I look suggest the top gear at around 11 oclock. Can you straighten me out so I can put the timing belt back on thankyou so very much dan bender
(Merged)
KHLOW2008
CERTIFIED EXPERT
Refer to diagram
Image (Click to enlarge)
(Merged)
THIS IS MIKE
CERTIFIED EXPERT
Danieljbender
August 17, 2015.
Thank you may I ask. You something my bottom gear is shown I bought Chilton manuel but the top gear would have to rotate by half and then would the rotor point to no.1 spark plug.? Thanks really daniel
(Merged)
THIS IS MIKE
CERTIFIED EXPERT
Danieljbender
August 26, 2015.
Thanks for u r help, I think I have the marks right, is it correct the rotor should point to o1 and then on piston at tdc, how do you know if it is on compression stroke thanks again
(Merged)
SNAKEAE86EK
MEMBER
1 POST
Engine Mechanical problem
1995 Mitsubishi Mirage 4 cyl Front Wheel Drive Manual
i wanna know the timing marks for my 1995 mitsubishi mirage ls 1.8 engine
