DUAL-PRESSURE SWITCH 1. With engine off, disconnect pressure switch connector (located on receiver-drier). Connect a jumper wire across high/low pressure side of harness connector. See Fig. 4 . Install manifold gauge set to high pressure side service valve of refrigerant line. 2. Start engine and adjust engine speed to 1000 RPM with A/C clutch engaged. Turn blower switch on. Engine should be warm and doors and windows closed. 3. Check for continuity at pressure switch terminals with manifold gauges at specified pressure. See PRESSURE SWITCH SPECIFICATIONS table. Condition is normal if there is continuity between the terminals. If there is no continuity, replace switch.
May 23, 2010 at 8:42 AM
DON SAMSONITE
MEMBER
1 POST
I had this problem and had to get a new cycling switch cost me $56.00 I love this site
Jul 5, 2019 at 7:30 PM
VITTELLI
MEMBER
I just bought a 95 mitsubishi mirage with 95000 miles on it. it runs great but when i turn on the AC it blows warm air. Is there a way to recharge it easily or would i have to have it done at a shop?
Jul 7, 2019 at 1:04 PM
(Merged)
LEGITIMATE007
CERTIFIED EXPERT
if your vehicle has already been retrofitted, to 134a which I think it has, then yes, its very easy, get yourself a big can with the meter on it, and follow the directions, its that simple, do not be intimidated
