1995 Mitsubishi Mirage Where is the fuel pump/relay fuse
1995 MITSUBISHI MIRAGE
80,000 MILES • 4 CYL • 2WD • MANUAL
MITSUBISHI 95
My car does not start, starter and battery both in good condition. Want to check 1st if the fuse is good or bad.
Mar 13, 2009 at 12:02 AM
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Mar 13, 2009 at 12:08 AM
