1990 Mitsubishi Mirage Air tube
1990 MITSUBISHI MIRAGE
HENRIUX
Engine Mechanical problem
1990 Mitsubishi Mirage 4 cyl Two Wheel Drive Manual
The issue is in the air tube.
There air oil present in the tube, is like that is going back.
What could be the cause?
Thanks for your help.
Henrius from Costa Rica.
Jul 19, 2010 at 1:31 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Are you referring to oil being in the air induction hose that connects the air cleaner to the throttle body?
Mark (mhpautos)
Jul 19, 2010 at 3:10 AM
HENRIUX
Yes you are. Thats exaclty the problem. sorry my native language is Spanish. I take the picture from this page. Hnerius C.R
https://www.2carpros.com/forum/automotive_pictures/551881_throttle_2.jpg
Jul 20, 2010 at 11:37 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
If you are getting a build up of a thick sticky deposit at the butterfly valve this is normal, well not normal but something that happens with fuel injected cars, you only need to clean the throttle body and valve with throttle body cleaner, just spray and wipe away, this should be done at every service so i dose not build up,
Mark (mhpautos)
Jul 21, 2010 at 1:03 AM
HENRIUX
Hi Mark,
Thanks for your answer.
I'm going to do that you say. Next time I'll tell you the results.
thanks a lot.
Jul 21, 2010 at 8:17 PM
