1995 Mitsubishi Magna How to replace starter motor on v6
1995 MITSUBISHI MAGNA
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
SLIPSTREAM99
I need to replace the starter motor and was wondering if there are any difficulties in removing and replacing the part. My car is a Mitsubishi Magna in Australia, but I think it is called a Diamante in the US
Feb 25, 2009 at 2:33 AM
Starter motor easy to change in the magna, disconnect the battery first, then undo the connections on the starter motor, 14mm socket to losing up the 2 bolts and its out. Then just a case of fitting the new one in its place and connect everything back up they way it was.
Here is a guide that will show you what you are in for when changing the starter motor
Please let us know happens so it will help others.
Best, Ken
Dec 14, 2016 at 7:29 PM
