Engine Performance problem
1996 Mitsubishi Legnum 4 cyl Front Wheel Drive Manual
Hi there,
Im looking for spark plugs for a 1996 Mitsubishi Legnum 1.8 GDI (4G93 - EA1W). I've talked to various people only to get mixed results. The two part numbers i've found are BKR6EKUD (currently installed in the car) and PZFR6B (this is what the local parts stores have listed). I emailed a mitsi mechanic who said that the BKR6EKUD is a specially designed plug for GDI engines and this is what i should use, however i've had another mechanic say to me that those plugs are designed for the turbocharged engines and i should use the PZFR6B (platinum plugs). The car runs well with the BKR6EKUD plugs that are installed but i dont know if the platinum plugs would be better. Can you offer any advice?
Cheers,
Murray
Hi there,
Cheers,
Murray
Apr 23, 2009 at 9:06 PM
