1997 Mitsubishi Lancer vibrations when air conditioning is
1997 MITSUBISHI LANCER
EMELEO
  • 5 POSTS
Air Conditioning problem
1997 Mitsubishi Lancer Engine Size unknown Wheel Drive Type unknown Automatic 150000 miles
my car vibrates a lot when i have the air conditioning on and select drive or reverse. the vibrating continues until i apply the accelerator. so if i stop at a light i have to nuetral the engine, the air condition is not very cool either.
Mar 5, 2008 at 1:00 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
There should be an idle up system fitted so when the A/C is on the base idle is increased to cope with the load. have the system pressure tested as you may have a refrigerant leak causing temp problems.
mark (mhpautos)
Mar 10, 2008 at 5:05 AM
