1996 Mitsubishi Lancer Good day!
1996 MITSUBISHI LANCER
119,000 MILES • 4 CYL • FWD • MANUAL
MARCIALALOVERA_27
My car problem is when i drive in low gear in first or second gear it driveslike a horse it is dragging what is the problem wiyh that? i already replace spark plug (new) friend told me that i need to relpace also the spark plug wires does it need also? please help me thanks!
Mar 28, 2010 at 10:45 PM
You sure the clutch is not slipping if not do below
Inspect and test all the following listed below:
Oxygen sensor
Catalytic converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Cap and rotor
Note: If it doesn't apply disregard.
Mar 28, 2010 at 10:49 PM
