2002 Mitsubishi L200 crankshaft removal
2002 MITSUBISHI L200
129,000 MILES • 4 CYL • 4WD • MANUAL
BURTON91
Hi there,
Hopefully you can help, i have an mitsubishi l200 2.5 TD and the bottom end has gone. I have stripped the block apart from the crankshaft, where the flywheel mounts to the crank it has a mount which i need to remove, in order to remove the crank for re-grinding but i don't know if its a left hand thread? if it is, its on really well because i've tried everything.
Thanks, Dave
Jun 1, 2010 at 3:33 PM
KHLOW2008
  • 41,814 POSTS
Hi Dave,
Thank you for the donation.
For Mitsubishi engines, there are no left hand thread bolts. All bolts are right threaded.
Jun 3, 2010 at 10:56 AM
