How do I remove the brake master
2004 MITSUBISHI GALANT
100,000 MILES • 4 CYL • FWD • AUTOMATIC
CVELEZ488
How do i remove the brake master. Do i have to remove the nuts?
May 1, 2009 at 10:59 PM
Replacing the brake master cylinder isn't too hard of a job. And yes, you need to remove the two nuts that mount it to the brake booster.
First, here is a link that shows how in general one is replaced. You can use this as a guide.
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
The new brake master cylinder will need bench bled before install. Here is a video that shows how that is done.
https://youtu.be/WDxvEQrMkBg
Here are directions specific to your vehicle. The attached pics below correlate with the directions.
______________________________________
2004 Mitsubishi Galant L4-2.4L (4G69)
Removal and Installation
Vehicle Brakes and Traction Control Hydraulic System Brake Master Cylinder Service and Repair Procedures Removal and Installation
REMOVAL AND INSTALLATION
Part 1
pic 1
Part 2
pic 2
MASTER CYLINDER ASSEMBLY AND BRAKE BOOSTER
INSTALLATION SERVICE POINTS
pic 3
>>AB
Mar 12, 2021 at 9:40 PM
