2003 Mitsubishi Galant BLOWN ENGINE
2003 MITSUBISHI GALANT
82,000 MILES • 4 CYL • FWD • AUTOMATIC
JCOOKINPS
A water hose burst and in under 2 minutes my car shut off with the engine blown. I love the car but I question spending $1900.00 for a used engine for a car of this age. Also, I am concerned that the extreme temperature that caused the engine to fail may have damaged other parts under the hood. Does anyone have a suggestion?
Nov 23, 2008 at 9:24 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Have you had a mechanic confirm that your engine is indeed blown? Just because it will not start after overheating doesn't mean it is shot.. it could just be a single component.
However, if it is gone then that is completely up to you. Changing an engine in a foreign car is always going to be more expensive so it is your money and choice.
All other components should be fine except maybe the radiator could be cracked.
Nov 23, 2008 at 9:43 PM
