Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Mitsubishi
Galant
Drivetrain
Bearing Hub
Replace/Remove
2002 Mitsubishi Galant Rear passenger wheel hub replacement
2002 MITSUBISHI GALANT
133,300 MILES • 4 CYL • FWD • AUTOMATIC
KAROI
MEMBER
1 POST
FOLLOW
Hi, Is the replacement of the rear wheel hub assembly relatively easy. Do I need any specialty tools? Thank you in advance.
Jake
Jul 16, 2008 at 1:05 PM
KHLOW2008
CERTIFIED EXPERT
Hi Jake,
Yes is quite easy and no special tools needed just the correct size spanners.
For drum brakes, you need to remove the drum and the centre nut and it is out.
For disc brakes, it invovles more work, you need to remove the brake caliper and mount assy plus the disc.
Jul 18, 2008 at 12:01 PM
