2002 Mitsubishi Galant ignition wires/ spark plug replaceme
2002 MITSUBISHI GALANT
76,000 MILES • 4 CYL • 2WD • AUTOMATIC
SLAVAN
I got my Mitsubishi Galant 2002 2.4 about 6 mos ago from a friend of mine. He told me he changed the spark plugs last may, but the wiring wasn't changed and it is evident. I have been getting check engline light that comes on and off for cylinder 2 misfire being detected and the car jerks during stops(with rmp btwn 4-6) also jerks when in drive and just when beginning to accelerate. I'd like to change the wiring, as well as check for the spark plugs and maybe change them and hope that will solve the problem of misfires.
My question is the 2nd cylinder wiring to the spark plug is just a coil. TO change that, it costs about 100 bucks, but i havent seen the wire set that actually goes into the coil itself. Are those wires to be changed at all ? If so how can i change them ?
Cylinder 1 and 3 have regular wires that i found at autozone, but nothing that looks like the wiring for cylinders 2 (where misfire is being detected) and 4, where only coil is present with a 2 by 2" box on top of it.
What should i do to solve this problem ? And will chanign the wiring help the jerking and the engine light to stop coming on? Can anybody walk me through the process of changing the wiring ?
I appreciate your help,
any input is valuable as i'm new to this and this is my first vehicle.
I went to strauss, they would charge 45 bucks for this wire change. Any advice?
Apr 22, 2008 at 12:00 AM
RAGULA2000
Hi Salvan,
I also have the same problem..Did u find a solution for it ..and can you advice me whether we can drive with this service soon lights on for a while.. I am planning to get it fixed after a while..
Thanks
Ravi...
Dec 20, 2008 at 2:01 PM
