Heater problem
2002 Mitsubishi Galant 4 cyl Two Wheel Drive Automatic 124K miles
My Mitsubishi Galant 2002 blows only cold air (The A/C seems to work fine). I checked with the dealer and he stated that the Hot/Cold pump needs to be replaced. If that is the issue (pump not working) even A/C should not work or car engine should get overheated. Am I correct? Based on the articles on this website it makes me feel that the heater valve is not working. Any suggestions?
Should I replace the hot/cold pump first and then check or should I replace the heater valve first?
Oct 23, 2010 at 8:36 PM
