2001 Mitsubishi Galant Leak under dash board
2001 MITSUBISHI GALANT
124,000 MILES • 4 CYL • FWD • AUTOMATIC
We have had 3 very hot days 90 degrees and above. I have water sporadically coming out of passenger side under dash board. I do not know if the drain is plugged. I cannot located the drain. Do you know where it is or what kind of problem would cause this?
It is condensation water.
Jun 10, 2008 at 10:19 AM
KHLOW2008
  • 41,814 POSTS
Hi pam,
Look for a rubber hose coming out of the firewall in the engine compartment at passenger side. It should be a cut off type or with a spout.
Squeeze it and see if water rushes out. try not to pull it out as you might have difficulty refitting it.
Any water into the vehicle over a period of time is just like a time bomb.
It could corrode electrical connections, blow out electronic items.
Jun 11, 2008 at 8:41 AM
