2001 Mitsubishi Galant help on my transmission
2001 MITSUBISHI GALANT
85,000 MILES • 4 CYL • 2WD • AUTOMATIC
INZANE27
i have a 01 mitsubishi galant and my transmission fluid is a little bit low. im currently searching for a transmission fluid that suits my car. i even bought a haynes repair guide. it saids that the only trans fluid i should put is diamond atf sp 3 or equivalent. now my question is, can i put Dexron III/Mercon Automatic Transmission Fluid instead of diamond atf sp3? will dexron mess up my transmission or my torque converter? because diamond can only be purchase on mitsu dealers and you know how much dealer charge you for that! im a little bit low on a budget because im still a student.
Aug 6, 2008 at 1:31 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I would be using the Mitsubishi oil as i have been advised by a transmission specialist that they are not that compatible with other oils, for the sake of a few extra $$ i would get the factory approved oil.
Mark (mhpautos)
Aug 6, 2008 at 7:48 AM
