Transmission problem 4 cyl Front Wheel Drive Automatic 101246 miles
Original problem - cooling tank in radiator busted and filled transmission with antifreeze. In result it took the transmission out. Since then I have replaced the transmission, radiator and lines. I installed Mitsubishi fluid and now when the trans. shifts from low gear it trips the check engine light and goes straight to third gear and stays there until you clear the code. Then it repeats the same. Check engine code says low gear not synchronized and the dealer says it was a bad transmission. Put another transmission with 40,000 miles in the car and it does the exact same thing. Where do I go from here?
Oct 31, 2009 at 10:57 AM
