1999 Mitsubishi Galant Crankshaft position sensor malfuncti
1999 MITSUBISHI GALANT
ANONYMOUSE
Engine Mechanical problem
1999 Mitsubishi Galant 4 cyl Wheel Drive Type unknown Automatic 116249 miles
I got an error code p0335 on an OBD reader. It says it is a crankshaft position sensor A Circuit malfunction. First can you tell me where the crankshaft sensor is so that I can replace it? Second the reading gave me the following results:
It had symbols indicating the code was pending. I have no idea what that means. Then it says the MIL status is OFF. It then displayed the word, Monitors and said 5 Inc.
It then said, Catalyst and evap. Then it read, 02 Snsr and then 02 HTR followed by the letters, Egr. It then read,
3 ready, misfire, fuel comp.
I am sorry, I know that is a lot of information but I have no idea what that means. I thought it might be necessary to find out before I change the crankshift position sensor and I have no idea where this sensor is located.
Thanks in advance!
Mar 17, 2008 at 7:20 PM
2CARPRO JACK
  • 11,533 POSTS
That sound slike monitor readiness..... just pay attention to the numbers, that is th etrouble code. The crank sensor is located on the front of the engine next to the crank sprocket, down low.
Mar 19, 2008 at 8:06 AM
