1998 Mitsubishi Galant Vibration when accelerating over 50
1998 MITSUBISHI GALANT
110,000 MILES • 4 CYL • 2WD • AUTOMATIC
DAVID JEROME
  • 5 POSTS
Why does a 1999 Mitsubishi galant vibrate at 50mph and over when you accelerate at that speed but when you cruise at that speed or higher, without applying more power it does not vibrate?
Oct 14, 2009 at 7:42 PM
BIG_JAY
  • 121 POSTS
If your vibration is only on accel then you might have bad cv axles. They are more common on hondas and toyotas but ive seen them vibrate on alot of diff cars. You should go have your tires balanced first but if it get worse as you accel and then stops when u let off it is most likley a bent axle.
Oct 14, 2009 at 7:58 PM
DAVID JEROME
  • 5 POSTS
[quote:82235dab92="Big_Jay"]If your vibration is only on accel then you might have bad cv axles. They are more common on hondas and toyotas but ive seen them vibrate on alot of diff cars. You should go have your tires balanced first but if it get worse as you accel and then stops when u let off it is most likley a bent axle.[/quote:82235dab92]
Big Jay,
Thanks for your suggestion. Sounds to be right-on. However, if cv axle is bent, would you not feel the vibration in the steering? You do not feel any vibration in the steering - only the body of car. Could an engine mount cause this? I believe I am alright in that dept. but no harm in checking.
Oct 17, 2009 at 12:01 PM
BIG_JAY
  • 121 POSTS
You will feel an axle vibration in the front of the car but not usualy through the steering. A motor mount is more of a bang and a jerk. To check your mounts start the car pull the e bake n hold the brake pedal tight then put it in drive and hit the gas pedal about 3/4 of the way down for a second. You will feel the motor jump and bang if you have bad mounts. Do the same in reverse to check the front mounts.
Oct 17, 2009 at 12:17 PM
