I purchased this car January 28, 2008 & after leaving the dealership it started "revving" out between 1st & 2nd gear and then an extremely hard shift. We then discovered it also had no overdrive. A couple of days later the check engine light came on & was diagnosed as cylinder 2 misfire & faulty speed sensor. We replaced all plugs, wires, etc & the speed sensor. Check engine light was reset & did not come back on. However the "revving" did not stop, nor did the hard shift & still no overdrive. The dealership got a used transmission for us & my husband installed it & the problem is no different except there is no "slamming" into gear (no hard shift). I find it unlikely we'd have the same problem w/ 2 different transmissions, however nobody seems to be able to offer any ideas . . . can you help???? Thank you, Jessica M. Bourn
Mar 19, 2008 at 10:45 AM
