1996 Mitsubishi Galant replacing brake rotors
1996 MITSUBISHI GALANT
AHMADSY1
Brakes problem
1996 Mitsubishi Galant 4 cyl Two Wheel Drive 120,00 miles
How complicated is the work involved to replace the front brake rotors on a 1996 Mitsubishi Galant
Dec 7, 2008 at 2:48 PM
ZACKMAN
  • 4,202 POSTS
Not at all. Raise vehicle Remove wheel Remove two caliper bolts and remove caliper Remove brake pads Remove two caliper bracket bolts and remove bracket Sometimes the rotor has one or two screw holding them in place. Remove them (if any) If the rotor seems does not want to slide out, spray some PB Blaster around the wheel bolts, and wait 10 minutes
https://www.2carpros.com/forum/automotive_pictures/55316_16pb_3.jpg
Use s soft-faced hammer and tap it
Dec 10, 2008 at 12:32 AM
