OK then have you checked to make sure the cable is adjusted right? Does it feel like it is in the gear as far as the shifter is concerned? I ask all these question because I do not have the car in front of me so I have to try to get all the info I can so I can try to determine what may be happening. So the more you can tell me the better it will help. I can't feel what is happening so I am depending on you to do that for me.
I cant help thinking you broke a CV axle which will make it seem like the transmission is not working. Here is a guide that will give you an idea of what to look for when changing it out. But first put the car in gear and use a flashlight to see if one of the axles is turning but the car is not going anywhere?
Mar 25, 2009 at 10:27 AM
