1995 Mitsubishi Galant exhuast and radiator
1995 MITSUBISHI GALANT
ROOM102
  • 6 POSTS
Engine Cooling problem
1995 Mitsubishi Galant 6 cyl Front Wheel Drive Automatic
everytime i start my galant. i see white clear smoke coming from the exhaust alot of it. an wen i tap gas theres even more an wen my engine heat up i start to see white clear smoke coming from around it an den the radiator fan kick in . i check everything an even change the motor oil. also my radiator the other rest of the water in the bottle on the side. everytime i have to keep fulling it like every 5 minutes an the radiator is full with clear tap water. help me please
Aug 15, 2009 at 10:50 PM
MHPAUTOS
  • 31,937 POSTS
HI there,
If you are loosing large quantities of coolant and you have excessive white smoke and steam from the exhaust you will be needing to have a head check done to check for a head gasket problem, do this first.
mark (mhpautos)
Aug 15, 2009 at 10:58 PM
