1995 Mitsubishi Galant engage
1995 MITSUBISHI GALANT
ROOM102
  • 6 POSTS
Transmission problem
1995 Mitsubishi Galant 6 cyl Front Wheel Drive Automatic
i have a 1995 Mitsubishi Galant. i have buy a new transmission for my galant. so now i bout some transmission fluid to put in it. 7 quartz bottle. now that the fluid is already in wen i start the car an run for couple of minutes, i have put the car in drive. the car wouldnt move at all i check reverse also, car still wouldnt move. i was ask to check to see how many fluid i must put. but i just got the car an they say 7 so i put 7. an from now the car still wouldnt move. its like wen i put it in drive it dont sounds like the transmission engage an the linkage is connected also. i need help please
Aug 15, 2009 at 10:40 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
There is an oil level mark on the dip stick, you should be checking the oil with the car running & in neutral, is there any oil on the dip stick and can you see the full mark on the stick?
mark (mhpautos)
Aug 15, 2009 at 10:52 PM
ROOM102
  • 6 POSTS
ok thanks but i have also check the level an its fine but the car still wouldnt move
Aug 16, 2009 at 10:32 PM
MHPAUTOS
  • 31,937 POSTS
There will be an internal problem that need to be investigated, so you now need to go get a few service tests done by a trans specialist, as this will require some special testing equipment.
mark (mhpautos)
Aug 17, 2009 at 5:13 AM
