1994 Mitsubishi Galant coolantg leakage
1994 MITSUBISHI GALANT
130,000 MILES • 4 CYL • FWD • AUTOMATIC
ANIRGUDE
I have just installed a new Water Pump - the antifreeze is still leakage from where the oil filter is. I inspected the oil, it looks normal (not creamish or milky). What could still cause the coolant to leake.
Thank you
Atul
May 20, 2009 at 2:52 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:4854ca08c0="anirgude"]Engine Cooling problem
1994 Mitsubishi Galant 4 cyl Front Wheel Drive Automatic 130000 miles
Thank you
Atul[/quote:4854ca08c0]
Hi Atul,
There are a couple possible causes...
You could have a leaking Freeze Plug in the area of the oil filter.
Or you could have a Blown Head Gasket that is blown to the out side of engine instead of inside. That could be why there is no coolant in the oil or vise versa.
If you can get a picture or 2 or 3 of the area and post them on here I could give you a better idea hopefully.
May 20, 2009 at 7:35 PM
ANIRGUDE
Sir/Ms:
I very much appreciate your response and I will include my donation shortly, I promise. I will take some pictures of the area of the leakage.
One question, if the head gasket is broken (presumablhy, worst case scenario), would the vehicle still start. The car is starting just fine, no hesitation or other starting problems.
Let me know and thank you again.
Atul Nirgude
May 21, 2009 at 2:58 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:4860aa17a2="anirgude"]Sir/Ms:
Atul Nirgude[/quote:4860aa17a2]
Yes, even with a blown head gasket the vehicle can run just fine especially if it is blown to the outside of the engine. You will just have to keep adding coolant so it doesn't overheat and cause more problems.
May 23, 2009 at 1:05 PM
