2005 Mitsubishi Endeavor Third Cylinder Misfire
2005 MITSUBISHI ENDEAVOR
123,000 MILES • 6 CYL • FWD • AUTOMATIC
JOSHUAFM
Hi, a diagnostic on my engine today indicated that it has a third cylinder misfire, which is causing the engine to shake when idle. What could be the causes of this, and what repairs could have to be made? At what cost?
Oct 28, 2009 at 6:50 AM
Hi joshuafm and TY for the donation
Costs of repairs on parts/labor varies with location
A misfire on a specific cylinder should prompt you to check sparkplug, compression and injector for that cylinder in your case cylinder no.3 other additional causes on misfires
Engine misfiring can be caused by the following worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Oct 28, 2009 at 7:27 AM
