2005 Mitsubishi Endeavor Car question
2005 MITSUBISHI ENDEAVOR
65,000 MILES • 6 CYL • 4WD • AUTOMATIC
GEEMONEY
When i am driving and press down on the acclerator their is some hesitation while speeding up
Aug 14, 2010 at 7:03 AM
Inspect and test all the following listed below, we start here I know its alot of checking and testing
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking,fuel filter or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Aug 14, 2010 at 8:42 AM
