APPLICATION
LABOR TIME V6 8.0 hr
Maintenance DetailsÂ
Add Detail Lines as Notes Please Note: Maintenance detail items may include multiple vehicle configurations. Therefore, it may be necessary to edit the detail items on the worksheet. 60,000 Miles (96,000 Kilometers) : All Applicable Models
OPERATIONCOMPONENT
INSPECT BALL JOINTS
INSPECT BRAKE HOSES
INSPECT BRAKE LININGS
INSPECT COOLANT HOSES & CLAMPS
INSPECT DISC BRAKE PADS & ROTORS
INSPECT DISTRIBUTOR CAP
INSPECT DRIVE BELTS For generator, water pump and power steering pump.
INSPECT DRIVESHAFT/PROPELLER SHAFT DUST BOOTS
INSPECT EVAPORATIVE EMISSION SYSTEM Except EVAP emission canister.
INSPECT EXHAUST SYSTEM Check and service connection portion of muffler, muffler pipes and converter heat shields.
INSPECT FUEL HOSES
INSPECT FUEL SYSTEM Inspect tank, pipe line and connection, and fuel tank filler tube cap. Check for leaks.
INSPECT STEERING LINKAGE SEALS
INSPECT SUSPENSION SYSTEM
REPLACE AIR CLEANER/ELEMENT
REPLACE AUTOMATIC TRANSAXLE FLUID
REPLACE CABIN AIR FILTER
REPLACE COOLANT
REPLACE ENGINE OIL
REPLACE ENGINE OIL FILTER
REPLACE IGNITION CABLES/WIRES
REPLACE MANUAL TRANSAXLE FLUID
REPLACE SPARK PLUGS Platinum-tipped spark plugs.
REPLACE SPARK PLUGS Standard Type.
REPLACE TIMING BELT
ROTATE TIRES
Jun 2, 2020 at 12:43 PM
(Merged)
