2003 Mitsubishi Eclipse Powertrain Control Module
2003 MITSUBISHI ECLIPSE
69,300 MILES • 6 CYL • 2WD • AUTOMATIC
EGARCIA41
When I changed from Park to Drive in the car, there is a hard shifting, and when on the road it has trouble changing gears. Took the car into a tranmission shop where they diagnosed the problem to be the Powertrian Control Module with code P0622. Shop told me that I need to replace the PCM which is $1K. Is that really what I need to do, or is there a simple check that I can do? Do I need to replace anything else along with the PCM and what is it and is there possibility of damage to the transmission?
Oct 30, 2008 at 1:55 PM
2CARPRO JACK
  • 11,533 POSTS
As long as they checked the generator fr circuit, the only other cause listed is a failed PCM
Oct 30, 2008 at 8:29 PM
JAMES W.
  • 2,394 POSTS
For a grand, I would sure get a 2nd opinion. Then, taking the age of the vehicle, there has to be a used unit somewhere that has some kind of warranty. Most salvage have a national hotline they can search. As far as damage to the transission, the more you drive it, the worse it will get.
Oct 30, 2008 at 8:34 PM
