2003 Mitsubishi Eclipse clutch problem
2003 MITSUBISHI ECLIPSE
FISHNSHELLS
Transmission problem
2003 Mitsubishi Eclipse Manual 35001 miles
i would like to know the proper way to bleed the slave cylinder there seems to be a leak somewhere
Jun 26, 2008 at 7:39 PM
KHLOW2008
  • 41,814 POSTS
Hi fishnshells,
If there is a leak, you need ot get it repaired. Bleeding would not help.
Ask some one to depress and hold the clutch pedal. Release bleeder nut and retighten. Pump the pedal a few times and repeat the above. Repeat until there is no more air coming out of the bleeder. Remember to use a transparent hose to connect to bleeder nut with a collection bottle.
Jun 29, 2008 at 10:41 AM
