2002 Mitsubishi Eclipse car stall / wont come out of park
2002 MITSUBISHI ECLIPSE
188,700 MILES • 4 CYL • FWD • AUTOMATIC
PARKEN
I was driving my car about 45mph when my cat stalled. I initially heard a high pitch whine, then my cat stalled. I put the car in park and then could not move the transmission out of park. When I tried to restart my car, it would crank but not turn. The sound was almost like it would be a dead battery, but lights, radio, and windows all worked.
What could this be??
Jul 3, 2010 at 11:39 PM
KHLOW2008
  • 41,814 POSTS
Hi parken,
Are the dash indicator lights showing?
Jul 4, 2010 at 5:05 AM
PARKEN
yes they are showong up
Jul 4, 2010 at 6:58 AM
KHLOW2008
  • 41,814 POSTS
Are you able to crank the engine? Crank means the engine is turning. If there is only a click and the engine does not turn, means it is not cranking.
If the engine is cranking and not firning up, it is a different.
Whining noise before the engine cutting out does not sound good.
Check if there are any engine oil.
For further diagnosis for not starting, click the " First Things To Check " link at bottom of post.
Jul 4, 2010 at 1:12 PM
PARKEN
engine is firing but not turning over. I checked the oil and it was fine.
Could it be computer related? Since the engine is cranking but not firing and I cannot release the car out of park, I did not know if the computer module would control all of these functions.
Thanks!!
Jul 4, 2010 at 1:36 PM
KHLOW2008
  • 41,814 POSTS
Check if the stop lights are working. When the stop lights fails, you would not be able to shift out of park.
That could mean you have a blown fuse which can cause non starting.
Jul 4, 2010 at 1:47 PM
