2001 Mitsubishi Eclipse Wheel Studs
2001 MITSUBISHI ECLIPSE
100,000 MILES • 6 CYL • 2WD • MANUAL
F16BULLET
I need to replace a rear wheel stud. The rear wheels have drum brakes. Do I need to remove the rear hub to have access to remove the broken stud and insert a new stud? If so, what can I use or how do I remove the rear hub? Thanks
Jul 9, 2010 at 11:16 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Raise the vehicle and safely support it with jackstands, then remove the wheel. Remove the brake drum. If necessary to provide clearance, remove the brake shoes. Using a large C-clamp and socket, press the stud from the axle flange. Coat the serrated part of the stud with liquid soap and place it into the hole.
https://www.2carpros.com/forum/automotive_pictures/261618_0996b43f8022cd12_1.jpg
To install: Position about 4 flat washers over the stud and thread the lug nut. Hold the flange while tightening the lug nut, and the stud should be drawn into position. MAKE SURE THE STUD IS FULLY SEATED, then remove the lug nut and washers. If applicable, install the brake shoes. Install the brake drum. Install the wheel, then remove the jackstands and carefully lower the vehicle. Tighten the lug nuts to the proper torque.
Jul 9, 2010 at 12:50 PM
