2001 Mitsubishi Eclipse water leaking into car
2001 MITSUBISHI ECLIPSE
69,587 MILES • 6 CYL • FWD • AUTOMATIC
JOHN COATES
My eclipse has started to leak water into the driver and passenger sides of the front of my car. I suspect it is probably something to do with the air conditioner. However, if you have any other suggestions as to where I should look I would appreciate your expertise.
Thank you,
John Coates
Jun 12, 2008 at 10:06 PM
KHLOW2008
  • 41,814 POSTS
Hi john coates,
Check and see if the cooling coil drain hose is clogged.
Jun 13, 2008 at 10:26 AM
