2001 Mitsubishi Eclipse Thermostat or Radiator?
2001 MITSUBISHI ECLIPSE
80,000 MILES • 4 CYL • 2WD • MANUAL
LJM548616
Right when I start driving the heat meter will jolt the the half mark between Hot and Cold. But if I do not put the heat on for the ac, it will rise on the meter and almost reach the Hot mark. What will I need to replace? Radiator, thermostat, the tubes? Please and thank you
Apr 13, 2008 at 1:17 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
replace the thermostat and have the radiator flow tested, check the cooling fans are working and have the sender checked for proper operation readings.
Mark (mhpautos)
Apr 13, 2008 at 6:18 PM
