Thermostat Housing leaking anti-freeze? What does this mean?
Mar 12, 2010 at 5:35 PM
NEFI154
MEMBER
the metal might have warped due to whatever reason. try simply changing the gasket or using some silicone.
Oct 20, 2010 at 11:47 AM
DAVIDPLETKA
MEMBER
1 POST
Engine Cooling problem
2001 Mitsubishi Eclipse 6 cyl Two Wheel Drive Automatic
Where is the thermostat located on a 2001 Mitsubishi Eclipse GT V6 and is it easy to get to?
Aug 12, 2019 at 7:52 PM
(Merged)
CERTIFIED EXPERT
Removal service point
<> radiator lower hose disconnection
Place mating marks on the radiator lower hose and hose clamp before disconnection.
(Merged)
JB49
MEMBER
1 POST
The engine was running very hot I replaced the thermostat. Now the engine runs very cool and I get no heat. Have I done something wrong?
(Merged)
BLUELIGHTNIN6
CERTIFIED EXPERT
sounds like you installed thermostat backwards..ensure thermostat is installed correctly like picture below
this guide will help
(Merged)
NAKIA64
MEMBER
1 POST
Where is the Thermostat located on a 2000 mitsubishi eclipse. I think its near the back by the battery but not sure.
Thanks
(Merged)
MRMIKIE
MEMBER
Your car has two radiator hoses, upper and lower. Follow the upper hose to the engine. The housing the hose is connected to houses the thermostat inside. Remove the hose and you will see some bolts on that housing, take those off and you should be able to get to the thermostat. Just remember to get a new gasket too.
(Merged)
LISA KERANS
MEMBER
1 POST
2000 Mitsubishi Eclipse 4 cyl Automatic
where is the thermostat located and the heater core?
(Merged)
BLACKOP555
CERTIFIED EXPERT
thermostat is located in the thermostat housing where the upper radiator hose meets the engine,
the heater core is located under the dash in the air ducts.
