Engine Cooling problem
2001 Mitsubishi Eclipse 4 cyl Two Wheel Drive Manual
I recently bought a new radiator to replace the cracked one on my 2001 Eclipse GS. The manufacturer stated that this radiator will work with both manual and automatic transmissions. When I took my car to the shop they immediately said it's the wrong radiator because it had a bleeder line on the bottom for an automatic transmission. The bleeder line is removable, and I explained that the manufacturer said you could use it with both transmissions. They are now insisting that you can't leave the holes open where the bleeder plugs in to the radiator. The want to order a new radiator, what should I do??
Nov 11, 2009 at 11:04 AM
