Engine idling rough
2001 MITSUBISHI ECLIPSE
134,876 MILES • 4 CYL • FWD • AUTOMATIC
THOMASMWARDIII
When the car is in park or in gear while running it idles very rough. for example, sitting at a red light or while in park with the engine running. It seems to idle below 1,000 RPMs. but it will slightly move up and down? Do you know what the problem could be or what part i might need to replace to fix? The car is an RS model.
Mar 4, 2010 at 7:06 AM
It sounds like you have a vacuum leak, or the throttle bore is dirty and needs service. I wanted to ask do you have a check engine light on. If so, let's run the codes these three guides can help us see what's going on so we can get the problem fixed:
and
and
May 30, 2022 at 4:39 PM
