2001 Mitsubishi Eclipse A/C Heater
2001 MITSUBISHI ECLIPSE
155,000 MILES • 6 CYL • 2WD • AUTOMATIC
MCCORMWP
Water is somehow leaking into the interior driver side on the floor. The driver floor mat is continuously wet. What can be making this happen and is there an easy solotion that i can do to fix the problem?
Thanks,
Bill
May 23, 2010 at 10:54 AM
WILL681
I have the same problem. If you look to the right of the gas pedal while the A/C is on you will see a steady stream of water coming down. I have been unable to fix the problem. If you get a solutions please post back!!! Thanks.
-Will
May 24, 2010 at 12:55 AM
