2000 Mitsubishi Eclipse erratic acceleration
2000 MITSUBISHI ECLIPSE
102,000 MILES • 4 CYL • FWD • MANUAL
  • 44 POSTS
So I understand the first reaction to what I'm about to say would be to get a tune up which for my car as I understand it could run me up to $400, an amount I don't have. So I'm looking for simple initial steps that I could do myself.
From 1000 to 4000 rpm's my acceleration stutters and acts as if gas is straining to get in there. This clearly led me to put in the liquid medicine prescribed by my local autozone employee ( fuel system complete care -- for injectors, etc,
) Then I put in an octane booster and a gas treatment. None of which were at the same time. I've had an oil change. I cleaned the throttle body . The only thing that helped was changing the spark plugs and things ran perfectly for like 20 minutes until the car got hot and then everything went back to normal. So I checked the spark plugs to see if anything was burn't or other visible issues but found nothing. Replaced and found car still having the problems.
HELP!!
thank you!
Nov 18, 2009 at 1:38 PM
The following below could be the caused:
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Nov 18, 2009 at 4:24 PM
