well hi i was woundering why my car idles at 1000 rpms while in park and also is at the regular temperature.please i need help
Jan 17, 2009 at 6:10 PM
KEVIN12881
MEMBER
low idle can be a number of things. could be throttle control sensor, idle speed, or you could need a tune up. are your plugs up to date? also see vacuum leaks EGR valve air filter fuel filter....do you have a lack of power or just low idle?
Jan 17, 2009 at 6:25 PM
FRANCKY21
MEMBER
Well i recently put new spark plugs and new cables, but this started since i clean the throttle with carbulator cleaner and since than it has been running while in park at 1000. Well when i put it on gear the car idles at 650 rpms and there is no rough idle. also, while running in shift a little hard. Thanks for the help
Jan 18, 2009 at 1:17 PM
KEVIN12881
MEMBER
donate a few dollars to get a pro to help. Low idle may not be all that bad, may just need turned up. Go to a auto part store and have them pull the codes. advanced and auto zone do it for free. Check your trns fluid. If you still have plenty of pick up with gas pushed in, check that air filter and fuel filter. fuel pump may also be going.
